• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home Troubleshooting Troubleshooting Basics
Troubleshooting: How do I rerun a job? Should I rerun jobs? Will it create duplicates?
Modified on: Mon, Sep 10, 2018 at 4:39 PM
What is re-running a job:
Any job, regardless of if it completed or failed, can be rerun in the jobs tab of your recipe. However, it will be rerun using the original trigger data, and will not pick up any changes made to the event. For example, if you have a recipe that was triggered when a new invoice was created, and you make changes to the invoice afterward, rerunning the job will not use the data from the updated invoice, but from the original invoice.
When should I re-run jobs:
Re-running a job will cause the trigger event to be passed through the recipe again, and this feature is useful in the cases below
1. A job that failed the first time, because the recipe was not accurately built.
2. The job may have completed, but did not process the event properly, for example, if you had a conditional statement wrong - you did not process it because it was in 'Paid' state, but you had mistakenly set the condition to 'If not Paid, Stop Job'. In this case, too you would like to fix the recipe and rerun the job.
3. The job completed fine, but the processing was not complete because of incomplete recipe definition. Many times, during testing, people incrementally build and test a recipe with the same job.
Duplicates
Duplicates may occur when jobs are rerun depending on how your recipe was set, so be sure to check and remove duplicates (if present) before re-running the job. To learn about duplicate prevention logic, check out this article: How to prevent duplicate records.
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
    Article views count
