• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home Recipe 101 General Best Practices
Adding Descriptions and Comments on Your Recipes. Markdown support.
Modified on: Mon, Oct 10, 2016 at 5:39 PM
Description:
We like recipe builders to describe their recipes well. This is because we built Workato as a community for building and sharing recipes and we want to make the recipes easy for sharing. When someone else is looking at your recipe, they will see the definition on top and decide if they want to look further down or not. We suggest the following format for describing the recipes, with a real example. The ### indicates that it is a Header 3, a ##### will be a header 5 and so on. The description text supports markdown, which allows for better display formatting, details can be found by clicking on this link.
Recipe description
Eventbrite manages your event tickets for you and Salesforce manages your contacts and accounts. When a new registrant signs up in Eventbrite, send the contact over to Salesforce and if there is an associated account attach a note to it.
### How it works
 Trigger: When registration in Eventbrite
 Actions:
 - Create contact in Salesforce
### Customization Options
 You can send emails out. You can check to see if the contact already exist.
### What you need to use this recipe
 No special setup or customization is required to run this recipe. You should have an Eventbrite and a Salesforce account that is enabled for API. Add your credentials in the connections section if you are not already connected to the apps.
Comments:
We also recommend adding comments to your recipe steps, especially if the steps are not obvious. To attach comments, you click on the comment button, that is the first button on the right hand set of buttons/icons. If you click on it, a Comment window opens up underneath.
How to Add a Description or Comment:
Have a suggestion on how to use Workato better? Post them on our forums here!
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
