• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home App Resources Google Sheets
Google Sheets: Search by Query
Modified on: Fri, Oct 14, 2016 at 11:18 AM
Search by query
These actions are meant to be used in synergy.
Search by query
The search query should be in this fashion:
age < 30 and height = 180
Compound searches with parentheses and 'or' commands work as well:
(name = "john" and pageviews > 5) or engagementrate > 15
Make sure that your query is correctly set up. It should have the following :
a) Column name in small letters without spacing
b) " " Between your data pill
The first thing you need to do is structure your query.
You can either type it out
Or use Data Pills from other steps of the recipe
Using Data Pills means you can manipulate data for your search query using Formula mode
What this action does is it generates an array (list) of the results in the standard data-pill-accessible format.
Do take note of the following limitations:
  1. Searching only works for single-word column headers. There must be no spaces in between
    1. Username works, but not User name
  2. Searches are not case-sensitive
    1. Searching for workato will return workato, Workato and WORKATO
  3. Search results are limited to 100 entries returned by the system
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
    Article views count
