Visit https://www.workato.com/integrations/quickbase for information about our Quickbase pricing plans, customer stories, examples of recipes and to sign-up for our Quickbase webinar.
Workato's Quickbase connector allows you to update a record in a table within an app. However, to perform an update, you need to tell Workato which record specifically you would like to update.
This can be done by providing a unique field that exists only for that record. In Quickbase, that field is the Record ID# field. This is a default field assigned to every record by Quickbase. (You may use another unique field or change the label of the Record ID# field)
Finally, if you update the Record ID# field label in Quickbase, do ensure that you enter the correct name of the field in the 'Input field list' and the correct field should appear.
