• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home Recipe 101 Recipe Basics
Understanding the Trigger: "From/Since" field
Modified on: Mon, Oct 25, 2021 at 12:23 AM
What is the From/since Parameter?
The "From/since" field allows your recipe to go back in time to pick up history objects that meet the trigger condition up until the present time and move on from there. This means that if you set it to "an hour ago", it will pick up events that occurred from an hour ago, and will continue picking up new jobs created afterward. You are either able to choose from the dropdown fields for certain apps, or you can click on the toggle and choose a specified date and time by clicking on the calendar logo on the left of the field.
DO NOTE: The since parameter will only work for the first time you run a recipe. After the first job has been processed, the recipe default behavior is to pick up where it left off. You will not be able to make changes to the field after your recipe starts. If you want to make your recipe go back further in time to pick up older jobs, simply make a copy of the recipe if you would like to make changes to the look-back date/time. Be careful when doing so as you might end up with duplicated records unless you set the trigger filter to not pick up records after a certain date. Check out this article on how to prevent data duplication.
Next: Understanding the Trigger: Trigger FIlters - How to reduce Transaction Count
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
    Article views count
