• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home App Resources HTTP
HTTP REAL TIME : Webhook Payload Example
Modified on: Sun, Nov 13, 2016 at 11:54 PM
2) An example Webhook Payload
Most of the application's API shows a sample of how the Webhook will return its result. By providing a sample response, Workato is able to parse these information into useful App Data pills that you can use in your recipe. For example, Eventbrite shows how a sample response will look like :
By copying this JSON payload into the Webhook Payload section, I can now acess these data in the form of data pills in subsequent steps :
I do not see it appear in the App Data. Why?
When the data pills do not appear on the App Data section, reason is due to the fact that the sample response data could not be parsed correctly, as it may not be in a correct JSON format. There are JSON checkers online that allows you to check if a certain data is in the right JSON structure, which can be easily accessible and free to use.
Another reason may be that your webhook type is PUT/POST with XML or Form encoded Payload, in which case they should follow the XML format or the Form Encoded format.
If you are unsure if your data should be in XML or JSON format, here is an article that helps you distinguish between the two.
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
    Article views count
