• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home App Resources Netsuite
How to successfully sync date fields in Netsuite
Modified on: Sun, Jan 22, 2017 at 10:13 AM
When trying to parse the date fields from the output of one Netsuite step to another, you may encounter errors as such:
  • Error calculating input for field 'startDate': invalid date
  • Invalid dateTime format: 2017-02-01
  • #<ArgumentError: wrong number of arguments (given 1, expected 0)>
To successfully map your date across, follow these steps.
Method 1: Check the input date pill's data type and value format
If the input date pill contains a string and is in the format of yyyy-mm-dd or yyyy/mm/dd or dd-mm-yyyy or dd/mm/yy, there is no need to turn on formula mode for the field.
Method 2: Format the string into an appropriate date using .to_date
Else, format the string into an appropriate date using the .to_date function. One example for the format would be %m-%d-%y. Refer to this for more information on date formats.
Method 3: Change the timezone and and format the string with strftime
If you are still encountering errors with mapping the date, you might need to add a function to adjust the timezone appropriately. For example, the formula to use would be
(Date Pill).in_time_zone("US/Pacific").strftime("%Y-%m-%dT%H:%M:%S%z")
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
