• DOCUMENTATION
  • WORKATO BLOG
  • PRODUCT BLOG
  • Return to Workato
  • Log in
  • Community/Discussions
Solution home App Resources Concur
Why don't I see my expense sheet custom fields in Workato?
Modified on: Sun, Feb 5, 2017 at 7:45 PM
If you're using the new expense sheet trigger in the Concur connector, you should be able to view the standard fields and custom fields in the datatree of the trigger (i.e. datatree will be visible in subsequent recipe steps).
However, if you're not seeing your custom fields, it might be because these custom fields were not configured in the Default Expense Entry type form. Workato currently pulls the custom fields out from the Expense Entry type form > Default form. For example, in the following screenshot, Project and Customer will show up as custom fields as they're found within the Default form.
If you can't view the custom fields you care about, check that:
1) the form is named exactly "Default", and
2) the fields you wish to see are within this "Default" form. If not, simply proceed to add them, then refresh your recipe schema in Workato.
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
