Error:
A business validation error has occurred while processing your request
What does this mean?:
Basically, a "business validation" error usually occurs when a required field is not filled in OR the field is filled in incorrectly.
Solution:
If you look through the error details in your recipe, it should specify more on what caused the error, for example: Business Validation Error: The type of name assigned to this transaction (client, vendor, employee) is wrong, or Business Validation Error: Something this action required is no longer available. Another user may have deleted it. based on the information, you may have to reconfigure your recipe, or go to your QBO instance, find the record that is causing the error, and manually rectify it.
Have a question? Join our bi-weekly Expert Hour to get help from our Experts. Alternatively, you can find similar questions in our Q&A (Recipe Errors) Forums or Start a New Topic.
