• Documentation
  • Workato Blog
  • Product Blog
  • Return to Workato
  • Login
  • Automation Institute
  • Documentation
  • Community Forums
Solution home App Resources SQL Server
Connect to On-Premise SQL Server with NTLM Authentication
Modified on: Mon, May 30, 2022 at 5:51 AM
In order to connect Workato to an on-premise Microsoft SQL Server database which requires NTLM authentication, these are the required steps:
  1. This step only applies to Workato OPA inferior to 2.10. Newer versions already bring the MS SQL JDBC Driver bundled. Add sqljdbc_auth.dll file to workato's OPA jre/bin directory. You can find this file inside Microsoft SQL Server JDBC Driver, which is available to download from Microsoft's web site.
  2. Remove username & password tags and add integratedSecurity:true  to your SQL Server profile on conf/config.yml
  3. Your configuration should look like this:
# Example on premise SQL Server NTLM configuration
database:
   ntlmsqlserver:
     adapter: sqlserver
     host: <hostname>
     port: <port>
     database: <db>
     timeout: 30
     integratedSecurity: true
Note (1): NTLM Authentication applies only to Windows installations of Workato's OPA, it is therefore not possible to authenticate from a Linux machine using the Microsoft JDBC driver.
Note (2): Also if you are running Workato's OPA as a Windows Service, be sure to check which account is being used to run the service. By default, newly configured services run as "Local System", which is a system account with no permissions at all.
Send feedback
Related Articles
    Documentation
    Developer's Library
    Tutorials
    eBooks
    Product Hour
    Product Blog
    Workato Blog
    Product updates
    Customer Stories
    © Workato 2022   Privacy   Terms   +1 (844) 469-6752
    • Documentation
    • Workato Blog
    • Product Blog
    • Solutions
    • Forums
    • Tickets
    • Log in
    • Return to Workato
    Article views count
